Re: 70 hp evinrude prop?
Hi Ken<br /><br />Without knowing the wide open throttle RPM's, it's next to impossible to say for sure if that would be the correct pitch prop for your boat. It's also hard to recommend without knowing the length or type of boat you're working with. The best thing I could advise would be to take your prop to a prop shop and they will know what size it is. If it performed well in the past, then stick with the same pitch. The wisest thing to do, would be to get a Tach. installed so there is no guessing...
