This is the first time I have done a water pump on my 1974 70Hp Evinrude. I have a J-E complete OEM kit. It came with a full face gasket. When I pulled the old pump out there was no gasket.
Do I use it? Does it go below the wear plate? Should it go on dry or with a sealant?
There is an O-ring at the base of the pump housing so that and some sealant is what I?m thinking for that surface. I have used Permatex #2 in the past on a 10Hp.
Any thoughts for this novice? I have the new impeller, new wear ring and new top plate all back in the new housing and ready to reassemble.
