I have been having the (seemling common) problem of throttle bog going to WOT and was doing some trouble shooting on the weekend. I took out the idle orifice plugs and unfortunately lost one. In looking up the part online, it calls for a #28 plug, but I'm sure the ones that were in there had 30C stamped on them. Do these numbers relate to the diameter of the orifice and will it make a difference which one I put in? Also, is it possible to run the motor with one of the plugs missing?
An unrelated issue is that a section of clear (?) hose supplying oil to the VRO has totally disintegrated. I assume this was there so that you can see if there is oil flowing. It looks like it went from an elbow on the end of the supply line from the tank to the intake on the VRO pump. I'm thinking that now may be the time to ditch the VRO...can I simply plug up that intake (does it need to be airtight) and disconnect the harness?
