70h Johnson VRO Troubles again
rustoleum
Not sure what year my motor is. But now I have lube , probably from the lower unit, coming from around the prop and out the back of the prop. My guess is seals. I'm familiar with changing lube in the lower unit and its drain and fill plugs, but not the insides. I 'm going to search for maunal today. I need to ask for help and if this is a do it your self job. I have tools and mechanical skills.<br /><br />Thanks in advance.
JB
Re: 70h Johnson VRO Troubles again
Howdy, Rustoleum.<br /><br />Not expert on lower end repair, but you need to know the model and year to get the right manual and the right parts.<br /><br />Post your model number and we should be able to help.<br /><br />Good luck. :)
