miichael18
- Mar 24, 2004
- 161
ok guys heres the story. 70HP evinrude took it out fired right up ran it about a mile up lake and it started cutting out loss of power. it would try to go then lose all power and would only run like 10mph wide open. it idles perfect but when you put it in gear it just bogs and dies everytime. has no power. So im thinking maybe carbs was dirty. took all 3 off cleaned good, checked firing all 3 coild firing good and put fresh plugs. checked compression all around 100 psi no big diffrences. Took it to lake same thing. fires right up idle perfect but when i put it in gear it just dies and when i do get it to go it will not open up and only runs very slow like its only running on 1 cylinder. I have changed the power pack 4 years ago the old one just died and engine would not fire at all. im getting good fire clean carbs idles fine but will not go when put in it just chugs and bogs and dies most time with no power. is this another bad power pack?? i hate to throw $120 bucks for a new one without getting more info or other things to check first. any info would be great thanks.
