70HP force RPMs
bullet09
I have a 70HP force i don't know the year but the serial number is OE137820. what is the idle RPM and WOT RPM.
Frank Acampora
Re: 70HP force RPMs
Idle speed on all Force 3 and 4 cylinder engine is 700-750 RPM IN GEAR, in the water. Don't know exactly with the 70, but again, all Force 3 and 4 cylinders were rated to run in the rpm range from 4500 to---- Your 70 might be 4500-5000 or it could be 4500-5500 WOT. Rated HP is probably developed somewhere around 5000. 5500 would most likely not hurt it.
roscoe
Re: 70HP force RPMs
you have a 1995 model.
4750-5250 rpm
I run mine at 5200+
5500 with the boat empty and an empty fuel tank
