any suggestions??
just picked up a little bayliner capri for a few hundred dollars. this boat was brought to the coast about one year ago and did not have a salt water anode. when I got the boat the motor would barely pivot by turning the steering wheel. I tried to spray the shaft with penetrating oil and work it loose. not much luck, you have to unhook steering and put a break over on it to move it now. is there anything I can try short of pulling the motor to fix this problem? any help/suggestions would be appreciated.
thanks,
gwmichie
thanks,
gwmichie
