I just put new kits in because fuel was overflowing into the airbox. I installed the carbs and squeezed the bulb to fill the carbs and gas was still overflowing out of the center carb.I took it back off and adjusted the float some more. Still the same problem. I have the float 3/4 inch and parallel as I can it get without exceeding the 3/4 in. mark with the float. What else could be causing the problem?
