Ok I've been putting off a build thread so I guess it's finally time. I started out with this boat after letting my campion go due to a bad hydro shift leg omc 120. The motor still had a little life left in it unlike my new calglass. So after taking my semi good gm 2.5 over into the calglass and it ran pretty good for a few months then I saw the block was cracked pretty bad, the. The bot sat on the back burner for almost a year. I decided to give the omc one last chance as this boat had a electric shift lower unit that was more plentiful in my area. So for months I searched for a good used motor and I found it in this parts boat
...well I thought it was good...
It looked great and clean low hours (500-700), turns out the head gasket went and it apparently sat for long enough that with cylinders one and four water made its way in and rust burnt it's way into the cylinder walls (possibly from rings?). Took it all apart and down to the machine shop only to find out that it would cost $700 before I had a rotating assambaly, barley covered the cost of machining and sleeving and honing and yada yada.
TADA!!!!!!
Outboard bracket, well in this picture it's a..well..workbench but its gunna stop all the problems I ever had with that piece of sh!* omc sterndrive...I never wanna hear that word again....sterndrive....
But of course everything's a journey and a life lesson for me so naturally.....
My freakin hub exploded in one of the worst parts of a highway around here that's one of the dangerous places to drive, at midnight, after a steep downhill right hand curve, at midnight so I wasn't very easily seen until I put my iPhone on strobe. To get people's attention. Anywho after scrapping a sad boat trailer off this wonderful one lane highway with the RCMP lighting up the scene once someone called for them and a wonderful tow truck driver I got the unit dropped off at a friends house. Yada yada boat sat on my front lawn while the trailer was getting fixed for 2 months my neighbours really hate me.
Back to it...rip that mother beepin omc garbage out!
Don't need those motor mounts!!!
There wasn't much left of them
TADA!!!!!!
