I have a chrysler 55hp motor model 55hd that ran great before running into a sandbar on the river with it. We hit the sandbar at about 20 mph and the motor buried itself into the sand and died when we hit and we had to get out and pull the motor and boat out. There was alot of sand in the exhaust. After hitting the sandbar the motor would start however it would sputter and die under the load of the water with any acceleration. We could tilt the motor keeping the intake in the water and it would pump water and accelerate fine, but in the water it would sputter and die under load. After getting it home we took apart the lower unit and cleaned it all out including the intake holes, and the exhaust. The motor will fire up and begin to idle fine, but will die within 10 to 30 seconds. It pumped water before the accident, but will not pump water now. I am going to inspect the impeller and water pump next. If the water pump was out would the motor still run but just overheat? I am trying to determine what might of happened to the motor when it buried itself into the sandbar and what is causing it to start but die right away. I would appreciate any feedback. Thank you
