Hello, I have a 1971 25hp Johnson. I replaced the thermostat and a bunch of other parts including ignition components, rebuilt the carb, new impeller, gear oil etc.
I noticed after running it, one side of the cylinder/ crankcase gets real hot. Almost to hot to touch. If facing the motor where the carburetor sits, the left side of the cylinder is real hot to the touch. I pulled the thermostat after it was warmed up and noticed it wasn’t open but it’s brand new (OMC) and it looks as though it was likely letting water through as everything looked wet in the housing. I also tested it in a bowl of hot water and confirmed its functioning. Anyway, is this normal to have one side real hot? I’m concerned I may have overheated the motor recently when I ran it hard on one cylinder unknowingly. I pulled the flywheel and noticed one condenser wire was shorted out when it rubbed the flywheel and this caused the loss of one cylinder. It’s now fixed and seems to run ok in the tub but haven’t ran it on the water yet, was hoping to get some info on possibly overheating.
Thanks in advance
Thanks in advance
