71' evinrude 6hp.........a little white smoke
BassBossAndy
Ok.......replaced the entire water pump assembly, put it all back together, runs great but the exhaust blows white smoke. Not a ton of it but enough to make me wonder. Has been sitting upright on a sawhorse for approx 6 months w/o running. Do I just need to give it a nice long run on the lake to blow some cob webs out of it? I'm new at this, sorry if this is a stupid question.
F_R
Re: 71' evinrude 6hp.........a little white smoke
But does it blow water? That's what's important. It's supposed to smoke.
1730V
Look at your sparkplugs. Is one real clean?
If so, you are ingesting water in the cylinder via the head gasket or the exhaust port cover gasket.
BassBossAndy
will look at spark plugs. Wouldn't it run pretty rough if I was getting water in there? It runs great.
steelespike
As suggested check the plugs.One or both may be extra clean.Oil smoke has
a blueish tinge and tends to linger "white smoke" is actually vaporized water,steam,and tends to disipate quickly.Motors can run quite nicely
if the problem isn't too bad.
BassBossAndy
Well thanks for all the help, looks like all I needed was some freshly mixed fuel. Ran her accross the lake this evening w/o a hint of trouble. Thanks again.:D
