Getting ready to install a hard to find seal kit in electric shift lower unit. Talked to many mechanics about seal direction and got several conflicting answers. Service manual says back to back in prop shaft housing and driveshaft bearing housing. Should the side of the seal where spring can be seen be considered the lip? Should proper direction be 1 lip out toward water and 1 lip in toward gear lube? Thanks for any help.
