i386
- Aug 24, 2004
- 3,548
I recently serviced the water pump on my outboard. It's the first time I've done it on this one. For those that have worked on a few Chryslers, this is one that has the threaded coupler w/jam nut that connects the 2 halves of the shift rod. You have to take the 2 cover half's off the exhaust leg to get to it.
Anyway, I was thinking the shift lever stood straight up when in neutral, but it leans about 45 degrees to the left. Also, the lock mechanism that limits the timing advance/throttle when in neutral isn't working. Other than that it seems to be working. What did I miss?
