kippstakes
- Jun 10, 2013
- 117
engine was running hot after i installed new lower unit. this model doesn't have an independent pee hole, so i installed a tap in the coolant jacket as an alternative. cranked her up today and only moist air is coming out, should be a steady stream.
don't think this model even has a thermostat, tho i could be wrong, so it should be pumping h2o constantly right?
i am also absolutely sure the ascending copper hose is connected to the pump on the lower unit, i re-installed the unit literally 7 times before figuring out a way to get them to mate up conclusively.
also, i installed the impeller immediately before mounting the unit, so i am sure that the key's in place and impeller's in fine condition.
any ideas? not sure how it could be blowing air with the pump intakes under water.
