I recently took the starter motor off my 1972 100 hp Evinrude. It seemed like it was turning the motor over slowly, so I thought I would check brushes, etc. There was grease in the end cap that was quite solid. so I basically just cleaned every thing and put it back together. The starter motor spins nicely now, however, the gear that turns the flywheel no longer rises to the occasion. Any suggestion on how to troubleshoot repair this would be appreciated.
I think the gremlin law is at work here, as I did nothing with this part of the starter. I just cleaned the interior bushings, armature, etc. of the field frame, and did not touch (except in handling) any part of the shaft and starting gear.
Please excuse if I am not using the correct part names, as I am not a mechanic by training.
