Re: '72 John 125hp Chokes out problem
I had a 1970 60Hp that kept giving me choke grief. It had a manual choke knob on the motor that I just plain removed. I mean it's not like you're actually going to be able to start it with a rope anyhow. I always wondered why they put a manual choke on the big motors. Anyhow it had three positions, Off-Auto-On. If it was either Off or On, it basically disabled all choke control at the choke switch.<br /><br />There was also an automatic feature that half-choked the motor when it was cold. I disabled that too. It flooded the motor when it was just a bit cooled-off, but too warm to need choking. If I recall correctly, the automatic circuit wire was purple with a yellow stripe and the electric choke switch wire was purple with a white stripe. I moved the p/y wire to the p/w terminal on the strip and it solved all of my choking problems. I don't know if yours has these, but if it does, give it a try. That'll put you in complete control of the choke at the choke switch.
