Good afternoon,<br />I have a 100ESL72R motor. I have had it on the lake 3 times and it runs great. There are two holes on the back of the motor just about waterline level. I thought this is where the cooling water was supposed to squirt out, but even 30 minutes on the lake there is only a slight oozing of hot water out of these holes at idle speed. I hooked up to the muffs and ran it for a minute and noticed alot water squrting out of a few holes down in the lower unit. The water coming out was warm which tells me it was going through the motor. The water would squirt out of these holes just from the pressure of the hose water, so I cannot tell if my impeller was pumping this water, or if it was just the pressure of the hose? Is there a better way to tell if i need to replace the impeller? I dont want to burn up the motor, but dont want to take apart if i dont NEED to ya know?<br /><br />Thank you very much
