72 Johnson 20hp felt like a clutch slipping
boulevard
I was out this weekend and when I had te throttle wide open with the boat loaded the engine would rev up but no more power was felt on the boat. I would let off the throttle and things went back to normal. It felt just like when your clutch goes out on a car and you give it the gas but the plates just spin and no power is felt.
What could this be? I didn t hear any strange noises other than the engine revving without any stronger forward propulsion. Thanks!!!!
Vic.S
Re: 72 Johnson 20hp felt like a clutch slipping
Spun hub in prop. Classic symptoms.
