liebe722000
- May 1, 2007
- 8
Hi all, i have a 72 merc 115 hp that friend says all is working cept the spring thing around distrubutor cap. Says it constantly lets gas in ? Problem ? It goes for awhile, like 30 seconds, then dies due to gas stops getting to carbs. Do i need a new spring thing ? Also what is the gas oil mix ? And is it ok for friend to rev VERY high in netural while checking. I said no cause you can blow a rod or piston ? Please advise. Thank You Mark Also friend says i put to much oil in last time. I put 1/2 quart to 6 gallons. When friend put midgrade gas in tank with no oil, it ran like crazy then died.
