ziggy
- Jun 30, 2004
- 7,473
Hi all, i'm haveing a hard time getting my lower gear assy. on after impeller replacement. i've determined that the upper shift shaft is what is preventing me from going together. when bolting up it distorts the washer on top of the lower shift shaft. something is binding in the upper shaft. the upper shaft will drop about 3/4" and has about a 20 degree arc which i feel is not correct. as i'm bolting up it seems that the upper shift shaft gets off center and hangs up on something inside the drive shaft assy. preventing me from bolting up. it's not that i cant hit the splines between the shift shaft and the upper shift shaft. that i got. also the remote is in forward, the gear assy. is in forward. what's up with my upper shaft? is it really suppose to drop 3/4" stright down and be able to move in a 20 degree arc. it also spins freely 360 degees. but feel that i have it (the upper shift shaft) in the proper position as when the remote is shifted back to N it moves in the proper direction to move the gear houseing shift shaft the right way for it to be in N. thanks for any help. jim
