"72"Penn Yann rewire
pennyann
I have a 72 Penn Yann I bought last year and am re-wiring the twin orig. Ford 351 engines.There are two stering stations with full inst. at each. The problem is someone who had the boat before me trided to correct problems with the wiring by scabing new wires onto some of the old and also just added others. In other words there are alot of wires that dont hook up to any-thing and others that are connected on one end but not the other.I cant figure out how to hook up the ign.,water temp.oil pressure,alt.,or tach because of the rats nest of wires.I am using all the original gauges but need to run all new wire due to corrision and confusion.Any help,or hint on where I can find a wiring diagram would be greatly appreciated! :confused: :confused:
D
DJ
Guest
Re: "72"Penn Yann rewire
PYN,<br /><br />Your wiring should not present anything mysterious. It's all straight forward wiring. Not much different than a 60's vintage car.<br /><br />It's a bit much to go into hear. However, there are many books on the subject. One that comes to mind is "The 12 Volt Bible" It amy be available here on iboats.
pennyann
Thanks guys! I ordered the book here DJOHNS, and really do appreciate it! I just couldnt figure out what went where when the wire colors changed two or three times between points! I have a one wire alt,the water temp wire,oil press. wire,coil wire,tach wire,choke :) wire,and solanoid wire and dont know where they go??? Also a 3 contact ign.
Ralph 123
Think of it this way. There are 3 main harnesses in a boat. The first is the engine harness. That is the wiring on the engines and it terminates with a connector mounted on the engine<br /><br />The second harness is what I will cal the cockpit harness. It runs from the connector on the engine to a connector under the dash. It carries your ignition wires, your senders, trim control, etc. <br /><br />The last major harness is the under dash wiring - the gauages, swicthes, etc. which plugs into the cockpit harness.<br /><br />Everything else is home run type wiring for the most part - that is wires running from point A to point B as needed.<br /><br />You should look into buying new matched cockpit and engine harnesses. Contact the mfg and see if they are available or you can often times find new harnesses on eBay - the issue is the connector between at the engines. Ideall you want to match what is already there OR replace the engine harnesses and connectors at the same time.<br /><br />If you take this approach you will save your self a lot of time and decrease the likliehood of making mistakes.<br /><br />When I rewired my Formula with twin 350s I used new Seray cockpit and engine harnesses. I then wired the new guages my self using all brand new guages and switches - no sense doing all this work and using old stuff. I made my own connectors for the dash/cockpit interface. You could also skip that connector and wire directlyto the cockpit harness if you wanted.<br /><br />You will need to purchase the correct tools - you need a high quality ratcheting crimper and a good automatic wire stripper and a good multi-meter and the very least.<br /><br />I can't emphasis enough that you need to understand the ABYC codes and fundamental good wiring practices for marine = military/space quality<br /><br />Only use Marine grade wire and connectors like that made by Ancor Marine.
