I have spent this summer resescitating this old boy. I got it running, but it never got above 3500 rpm, so I decided to check spark plugs. 1 & 2 looked fine (light brown powder), but 3 & 4 were oily, so switched plugs and no change. Swapped wires and no change.
Then decided to start testing the ignition system. Tested the coil by holding the coil lead close to block while cranking. Nice blue spark toward the block, then spark went back to pliers. Found a new OEM coil, installed it and proceeded with same tests. The results with the coil lead were the same, so figured it was deeper in the ignition system. Pulled flywheel (not fun!) and stator. The distributor cap is tightly stuck inside the stator. Is that normal? (or okay?). If not, any suggestion on how to separate?http://forums.iboats.com/images/smilies/confused.gif
Also, noticed a lot of oily grease on inside of cap by the ports for 3 & 4. Because those are toward the front of the motor, I figure it was overspray from fogging oil, etc, while getting the motor to start. Have now cleaned that as well as all spark plug leads. I do not particularly want to to re-assemble (including re attaching the flywheel) until I am fairly confident the problem has been solved. I tried to remove the sensor but I could not get the screws to budge at all. Any idea on how to remove stuck screws? (I will coat all screws and bolts with anti-sieze when reassembling). I would like to remove the sensor to check the small wires for possible worn spots causing inadvertant grounding.
I also checked the sensor gap. All were fine (at .028), but I noticed that the tab for #2 was tighter than the rest (had to remove feeler to turn the engine). Is it normal (or acceptable) for one tab on the trigger wheel to be slightly longer than the rest? If not, any suggestions for removing the trigger wheel?
Is there anything else I should check (or anything I am overlooking)?http://forums.iboats.com/images/smilies/confused.gif
Thanks for any and all feedback!
http://forums.iboats.com/images/smilies/smile.gif
