'72 Starcraft Holiday - Hull Repair Questions - 2nd Attempt
BOAH
I'm reposting a previous thread because I goofed up the previous one and I couldn't figure out how to fix it. Sorry about that!
Here is my '72 Holiday.
attachment.php
I bought this boat last spring with the hopes of getting an inexpensive functional boat that I can use for fishing, diving and just dragging the kids around with.
I knew that it had some engine issues and the hull leaked but I didn't mind because I got it for practically a song. After some time spent on the engine and plugging some leaks in the hull, we've had a great time with this boat.
To plug the leaks in the hull, I went at the seams and the suspect spots with a wire brush on a drill. I then sealed them up with 5200. I was in a hurry to get it on the water so I just used a cheap primer and paint to cover up the repairs.
As you can see by this picture, it truly was a temporary fix. Those strips hanging down are 5200!
attachment.php
So now I am ready to go after the hull again and hopefully do a little better job!
After looking at a number of other threads, it appears that I should probably go after it by going to the inside of the hull first, correct? If that's true, the problem is that the floor has been replaced with diamond plate that's been welded into place. If that's what I need to do, it's going to be pretty tough to do.
attachment.php
attachment.php
So if you have comments, suggestions or ideas, I would love to hear it.
Thanks for your help!
North Beach
Re: '72 Starcraft Holiday - Hull Repair Questions - 2nd Attempt
Boah,
You gotta get those pics fixed. Once we see what you got, plenty of folks will chime in with repair suggestions. Then you can sort thru it and make an informed decision.
coolbikeguy
are you using photo bucket ????
BOAH
Sorry about the pictures. I tried to attach them and get them to display in the thread but I'm obviously missing something. arghh...
You should see them now as attachments at the bottom.
Bob_VT
Well you have a few choices.
You can apply gluvit on the exterior and the hull MUST be flipped over.
You could use a cut off wheel and cut open places in the deck or entire strips to gluvit from the topside. Then your choice is to fashion a bolt down system for the decking or re-weld. I would go with SS bolts or aluminum rivets so you retain future access.
BOAH
