73 165 timing
schalmat
Hi all,,woking on my 73 165 I-6..found tdc and had to re-mark my balancer.could someone please tell me what the timing spec is on this motor,and what the correct plugs are for it..i dont have the mercruiser manual for it and have been unable to download it.thanks for any info........Matt
Re: 73 165 timing
Ayuh,... I believe it's timed to 6? Btc,.... The plugs I believe are AC MR43T,...
Somebody will correct me if I'm wrong,... :D
Bt Doctur
Re: 73 165 timing
you dont remark a factory balancer . more likely the rubber has slipped a bit.
ddrieck
Re: 73 165 timing
If the center hub to outer ring has not slipped....... you may not have it on TDC on the compression stroke.
schalmat
Re: 73 165 timing
Thats what I am thinking,I used a piston stop to find tdc, touched the stop ,cranked it around by hand till it stopped and split the distance,marked the balancer with a paint pen to line up with zero on the tab.The actual mark on the balancer is pointing at 11 o clock position and it should be bout 1 oclock position.. it hasnt slipped in or out .when im off this week i"ll put a light back on it and see where it is showing.Motor runs well just need to verify the timing ,,runs about 3700-3750 wot.Should be a little higher with 19p,So just verifying everything before a prop swap.also need to make sure mech advance is funtioning properly.The balancer will get replaced this winter when funds permit.Thanks for the replies and the specs bondo.
