73' 40hp evinrude, shift linkage adjustment
1506cmo18
Hey guys,
My motor goes in and out of gear but it needs some force..it actually broke my cable...
anyone know how to adjust it?
restornator
Re: 73' 40hp evinrude, shift linkage adjustment
it could be a number of things that caused the cable to snap. shifting at high idle, old worn out cable, sharp bends in the cable.
Is it hard to shift by hand?
1506cmo18
well whats happening is the shift cable isn't pulling the shifting mechanism all the way ahead...if I adjust the cable it will either go all the way into reverse and not forward or vise versa...there's is no in between....so I'd assume the linkage is worn out and I was wondering if there is any adjustment I can do on the motor
cable itself didnt snap, just striped the cable stop in the OMC controls..I purchased a new one today, thats when I realized that the cable can't pull the motor mechanism enough...
restornator
okay, that eliminates a lot. There should be a screw on the shift lever, left from where the cable connects. This screw connects the shift lever and safety switch lever to the shift mechanism. Loosen this screw and you can adjust the position of the shift lever. Tighten back up when you find the optimal position
1506cmo18
heres a picture of the motor....i dont see where I can adjust
restornator
There is a screw on the shift lever that syncs with the shift rod bracket and safety switch lever. I can see the screw, and it looks a little corroded. If you can't locate it on your own, you shouldn't own a boat
1506cmo18
Seriously?
Why would I sell the boat if I cant find a bolt on the motor???hah u can be smart mouthed and I can be too...dont be an a hole bud, just asking a question..
So that neutral safety connects to the transmission...learn something new everyday
restornator
sorry for the attitude, but it shouldn't be that hard to find
1506cmo18
No its not hard to find however I was looking under the motor where the shifter goes and not under the hood.
thanks again, ill post if it works, I'm just scared its withing the transmission is where the problem will be
1506cmo18
so I frig around with it today and it will go into reverse however its needs like 1/16 of an inch to go straight into forward. Is there any other adjustment that can be done?
All it needs is a touch by hand and you hear the click.
1506cmo18
Maybe internally the gears are worn causing the shifter to have to go so far a head to shift forward...
It seems that when it goes into reverse the shifter doesn't go far enough back and then when it goes into forward it goes to far a head. ...
