73' 40HP MERC 402 driveshafts
lazzlonewolf
i HAVE 2 LOWER UNITS FOR A MERC 402 '73s ONE IS LONG SHAFT THE OTHER SHORT. CAN I SWAP out just the shafts everything else is the same.unless the gears are different about to find out. just thought id ask if someone knew allready. ill let ya know if no one helps me
Chinewalker
Re: 73' 40HP MERC 402 driveshafts
Yes, the shafts should swap out with all else being the same...
