73 50hp johnson ignition switch
akita
i want to use a six wire ignition switch with push in choke in place of a 5 wire with a toggle choke. does anyone know if this is possible, and if so does anyone have a schematic showing wire colors and location. thanks
BoatBuoy
Re: 73 50hp johnson ignition switch
If you enumerate the wires and colors coming from the engine, someone here can tell you where to connect them on the new switch. I could tell you what mine is, but some colors may be different than yours.
