Hi all-
I have recently aquired this motor and was told it wasn't firing; i am a "tinkerer" and don't want to send this off and spend a fortune to get it fixed. I purchased a compression tester and a digital multi-meter. So far, i have tested each plug (new) and could not get even a mild spark to show... I have tested the rectifier per Engine FAQ's section and have validated that it is working correctly. I have also checked compression, all cylinders are between 118 and 122 PSI. I have looked under the flywheel and noticed the green epoxy is melted around the Stator (need puller to get flywheel off)
i plan on replacing the Stator and rebuilding the carbs later this week.
What is the next test for no spark? Thanks!
