That WI Guy
- May 10, 2002
- 5
I own a 1973 Chrysler Outboard, 55 HP, Model 555 HF, Serial no. 4803. (Coils located underneath the flywheel.)<br /><br />There are three wires connected to each breaker point. The first one is from the condenser, the second one is from the coil, and the third one goes to the engine's terminal block. Where should this third wire be connected on the terminal block? The terminal block has the following connections:<br />1. Yellow - Start<br />2. ..... .....<br />3. White - IGN - Tach<br />4. Green - Choke<br />5. Orange - Heat<br />6. Red - Battery (+)<br />7. Blue - IGN<br />8. Black - GND (-)<br /><br />Thank you.
