caseystuff
- Jun 16, 2008
- 10
I replaced the lower unit on this old motor, got it back together and the water pump wasn't pumping. Pulled it back out and fixed that problem, but after getting it all together, took it to the lake and it started right up and started moving away from the dock in forward. I took it out and it ran well, but would not go back into neutral. It will go into reverse just fine. If I just take out the bolt that holds the shift rod to the shift linkage cam, can I pull up the rod in some way to put it back in reverse - or do I have to take the lower unit off again?
Thank you, guys, for all the help!
