stoopidfish
- Oct 24, 2003
- 9
The old girls been setting for 3 years so I rebuilt the carb: new gaskets, float, needle. Sprayed a whole can of carb cleaner through every hole and everything seemed to flow fine but it will not start. It will run for a second with a squirt of starting fluid but there's no fuel coming out of the jet. I took the carb off and the bowl is full of fuel, the needle isn't stuck, the fuel line at the carb isn't blocked and after cleaning it again, I still have the same problems. The only thing I didn't remove from the carb were the two little plugs (don't know what they're called) because I don't know how to get them off. The slow speed adjustment needle is backed out all the way. This thing should be gushing fuel. Wuz going on? Any help would be appreciated! Thanks<br /><br />-fish
