I would like to swap a large geracase on a 1973 50 hp evinrude and put it on a 1976 55 hp evinrude that now has the smaller gear case. They look the same size dimensionally. Will this swap work OK and be beneficial to have a larger gearcase?
I need to play with some props to get RPM's in range and I have large gearcase props but only one for the smaller. I would rather run with the large gearcase on the 55 if possible.
I'm getting 4000 RPM out of a 11 3/4x17" prop and need to see if I can prop the RPM's up a little.
