Ok, I have just re-built all 3 carbs, the fuel pump, water pump, new ignition coil 725 cold cranking amp battery, new fuel lines, new shaft and rotor inside distributor, new cap, new wires, new plugs, and had a tech ensure all wiring was correct on my 1150 thunderbolt ignition. She will not start, if i spray fuel in the carbs through a squirt bottle hold idle rev up and hold choke down she will try and try almost firing every time she cranks for maybe one second after i let the key off then dies. I printed the link & sync out for my engine specifically and the front of the engine says on it what degrees it should be....just wondering if anyone has any step by step for timing this thing to advance or slow the spark or any info at all. Someone told me something about taking all the plugs out putting a dial indicator in #1 on tdc and zero the dial, turn flywheel back 1/2 inch then forward to whatever degrees the engine say's on it, then move the timing mark to match that number on the flywheel. then something about taking throttle off put timing light on #1 and doing something any better instructions or any help on ensuring the timing and spark is set right? Thanks for any help!
Tim
Tim
