Hello all, I just cleaned and rebuilt my carbs but I am not sure if I have the spring that goes between the throttle linkages and the choke installed properly. The throttle linkage kind of holds it in place but it seems a little loose to me. Does the part where it is bent on the right side of the first pic contact the choke linkage that is not hooked up yet? I don't want to be stuck when I put the carbs back on the motor so any help would be appreciated. Here are a couple of pics. Thanks...
