Re: 74 85hp Johnson will not run high RPM
Larry... What is the compression on all four cylinders? Should be approx 100+ psi and even on all cyls. Also, with the spark plugs removed, does the spark jump a 7/16" gap on all cylinders?<br /><br />Spark plugs should be Champion QL77JC4 or L77JC4 plugs, gapped at .040 . Are you using new s/plugs?<br /><br />Let us know what you find on those two checks.<br /><br />If the above checks out okay, I can only assume that you have overlooked something in the carburetors.
