surveywaters
- Apr 5, 2013
- 20
'74 Evinrude 25hp is flooding and won't start. This engine has sat up for probably 15 years. I've gone over it and done the typical inspections and maintenance. Now when I finally tried to crank it for the first time it flooded immediately. I installed a new float valve when cleaning the carburetor and it is sealing. It seems that it's just pulling too much through, it's even leaking out of the throat of the carb body once I start pulling, but not before, not even when priming. I was studying the microphiche and noticed #21, I am not sure I saw this part, does it seal the end of the main jet tower? The end of the main tower is huge compared to other jets on engines this size. Attached is the phiche I am refferencing. Thanks
