74' Johnson 25hp Compression question
commosmart1
My engine is fouling out brand new spark plugs within a few hours. I my gas/oil ration is good and I checked the compression and one cylinder is getting 123psi. while the other is getting 75 to 85 psi. Any ideas and what I should do?
Thanks,
William
SparkieBoat
Re: 74' Johnson 25hp Compression question
go to secret files section and find the decarb instructions...if that does not work remove your head cover and see whats up..
wilde1j
I would pull the cylinder head and hope for a blown head gasket. Let us know what you find.
commosmart1
Thanks can you give me a link to the secret file section, I cannot find it on here.
boobie
Way to much difference in compression readings. As suggested above, pull head.
kenmyfam
Agree with all the above. Whip off the head and check things out. For the cost of a gasket it is a small investment that can tell you so much.
