willard887
- Jan 30, 2012
- 64
Ok here it is..... ok i put my 74 50 horse powerhead on a different lower unit today. Engine run fine yesterday, got it together and took it out. Fist i notice exhaust leaking out from under powerhead and water running down front of lower unit. Got it .. I messed my gasket up during install, my question is why did it lock up right after that? engine just locked right up and died. i could see it was pumping water but it was weak, as soon as it locked it started right back up and would run fine then just lock up again. Now if the gasket is messed up and its losing water from reaching the block could this be the culprit? Or could it be gears in lower unit locking up? thanks in advance for help.
