'74 Johnson 50hp Outboard have alternator?
melvino
I was just curious if this outboard has an alternator? How can I tell?
Thanks in advance for answering my rookie question!
bktheking
Re: '74 Johnson 50hp Outboard have alternator?
Parts diagram shows a stator and rectifier so yes.
F_R
Sure it has an alternator. To test, clip a voltmeter (multimeter) to the battery and note the voltage. Then run the motor for a while. The voltage should increase as the battery takes a charge. If it does, all is well.
