SeaRay Seville
- Apr 24, 2017
- 17
Ive been fighting this for a year, when I first got it, it would run on all 3 randomly then kjck out to 1cyl only. Did the easy stuff: new tank, all new fuel lines and fittings, plugs, same result. tested compression good at 125 in all holes. New parts include Timer Base, all 3 coils, Rectifier, Stator, Power pack, overall check of all engine wires grounds wiring harness etc. If I shoot starting fluid in the top two holes they'll fire, pull fuel lines to those carbs and gas sprays out but when I pulled carbs they were dry in the bowl and the plugs are clean and dry like they were never ran? how can it not be getting gas??? could the spark be weak enough that it runs on starting fluid but not gas??? carbs look brand new exhaust gasket is good reeds look perfect in all holes and are not cracked or stuck, floats are not cracked or leaking, im ready to burn it and walk away...
