Short on time and experience, I put my boat in the shop for water-pump service, (3 yr since last done). They can't remove the lower unit after an hour of trying (stuck)
. Back end moves down only slightly (enough to wedge in a screwdriver), front end does not open at all. They pounded (rubber mallet) and pried to no avail and said the last time this happened, they ended up cutting the driveshaft, etc... $1200 repair! So... it looks like I'll be giving it a try here shortly. I have a manual and it appears that they got all the bolts (2 on each side, one near the trim tab and one under the trim tab), disconnect shift lever, etc. I have read ALL posts dealing with this topic... hardwood wedges (no place to insert)... loosening bolts and shifting forward/reverse?... Large prybar (no good opening to insert)... Bigger hammer??? The motor is mounted on the boat so inverting to get penetrating oil in is a big deal. Anyone got any advice/ideas for this particular model? Thank You
