74 rendova ignition coil wiring
I have a 74 rendova with a 305 Chevy v8... I have ignition issues... It cranks over just fine but there is no fire. There are 3 wires going to the ignition coil. Can you tell me what each wire goes to and how to hook it up on the coil?
GA_Boater
The boat doesn't matter and Chevy doesn't build I/Os. Who did?
On plus side of coil, purple wire supplying 9 volts via ballast resistor wire and yellow/red connected to starter i terminal
Coil negative would get wire from points and grey tach wire
Most likely you did not service the points
File points, gap points, verify dwell, set timing....go boating
