firstboat25
- Sep 2, 2005
- 98
Hi guys <br /> <br /> Not sure where to go on this so here it is <br /> I have rebuilt the carbs, replaced the power pack and coils and changed the plugs so I took the boat out. To begin with engine does not like low idle she will miss and backfire so I rasied the cable adjustment to max so it doesnt do that <br /> when I put her in gear she will go forward as soon as I give her more throttle she stalls the only way to get past that throttle up stage is to give shot of mixture into carbs they she will go and run, if I drop down to low speed she will throttle back up fine if I stop and the throttle up needs the gas again <br /> Am I lookin and a linkage problem ? I can reve it up when in neutral by hand opening the butterflies if I put her in gear have my friend give throttle and open butterflies she will throttle up fine<br /> Please help its getting cold here in Ny wanted to have this fixed before its to late <br />Thanks
