My '75 Chrysler 75 outboard starts fine when cold, runs great for about 15-20 mins then dies like the key was turned off. Let it sit for about 2 minutes, and it will start right up and run for 8-10 minutes then shut off again, wait a little longer, and it'll run for a shorter period, and so on.
The boat sat for three years until I bought it last February, and since I have had it, this is what I have done:
New battery. New gas tank, fuel lines, primer bulb, and fuel pump diaphram. I removed, dissasembled, and cleaned all three carbs and re-tuned them after putting them back on. New head gasket. New plugs. Removed thermostat, new water pump impeller.
I have had 2 stroke motorcycles do this to me in the past and it was always a bad coil, so I replaced the coil last week. No help.
Could it be the CDI unit going out? Don't those things completely die when they go, or can they become intermittent? It's a pricey part (and it comes with the coil, doh!). Is there something worth pulling the flywheel off to check? (stator, condenser, etc.) The CD box on it now is a CDI 115-3301, and the sticker on it reports a manufacture date of Oct. 2003.
Thanks in advance!
EDIT:
Also, I have bypassed the quick-connect on the gas tank and lightly squeezed the primer bulb while it was running and it still shut off. So I'm confident it's not a fuel starvation issue.
Thanks in advance!
EDIT:
