kevdog2000
- May 20, 2012
- 24
I have to replace the rotted stringers and floor on a '75 Crestliner Apollo and need a little advice. After removing the stringers, I still have the fiberglass mat that was used for tabbing attached to the hull. Do I need to completely remove the old fiberglass tabbing or can I grind it down a little and re-glass over it? Also, there appears to be dark areas on the bottom that look like mold(?) Do these areas need to be ground down to ensure good adherence for the new fiberglass?
This my first time attempting this type of project. Thanks for any help!
