forgedin78
- Aug 2, 2009
- 50
Having trouble, only getting spark on one cylinder, so heres what I have done:
using spark tester by the way, I suspected a bad coil, so I switched the plugs where the coils plug into the wires coming from the ignition plate, then I had spark on the cylinder I lost it on before, and the one that was working didn't work now, so they switched. This told me that the problem wasn't in the coil, correct?
Next i took off the flywheel, everything is tight, and where it belongs, points are set right, so for the hell of it I switched condensers from one side to the other. No change
Then I started thinking maybe the wire is shorted, or partially broken where it leaves the timing plate, so i unhooked both ends, tested for continuity, tested good.
Then I switched the wires that go from the points, out of the timing plate, and to the external coils. I swapped them from one side to the other, put back together and tested for spark. have spark on opposite cylinder again, SO that tells me from the points down to the plug is good correct?
Now I am suspecting the driver coil, it seems to be the only thing left, other than points. Is it even possible for one side of it to go bad and not the other, I took it out and tested it for continuity, and it tested ok, but I don't know if that even tests anything...??
I guess I will have to swap the points from one side to the other, that seems to be the only thing I can think of that I haven't tried.
Is there a way to test the driver coil??
any other suggestions?
