75 FORCE FUEL PROBLEM PAGE 2
Basin Dave
RAN OUT OF SPACE ON PAGE 1. WHEN BOAT IS RUN THE PRIMER BULB GOES FLAT ,AFTER A WHILE I CAN PUMP IT UP AGAIN AND RUN FOR A FEW MINUTES, THE OUT OF FUEL AGAIN ANY THOUGHTS? I ALSO RAN SEA FOAM THRU THE CARB.
moderator1
Re: 75 FORCE FUEL PROBLEM PAGE 2
You cannot run out of space, just keep typing.<br /><br />Please do not use all caps, it indicates that you are screaming at us.<br />Your second post has been locked and the contents of the second post were added to the first.
