Bought a 1975 Grew 194 with a 165 OMC sterndrive and a cracked block.
Want to ask a few questions before I go after a OMC manual. Has anyone found a on line source for a free manual? To swap engines does the Outdrive have to be removed first? I know the water was not properly removed from the block and it certainly is cracked. How does one check the manifold to see if it is ok or cracked internally? Would a car shortblock have the right holes for re-mounting?
Thanks in advance,
George
Thanks in advance,
George
