Re: 75 HP Johnson Electramatic LowerUnit
YepBlaze.... The "Hydro Electric Shift" lower unit came out in 1968, through 1972. CD's lower unit is one of the older V/4 engines (1964) that incorporated a straight "Electramatic Electric Shift" unit: 12v to green = Forward, 12v to blue = Reverse, No voltage to unit = Neutral.<br /><br />-------<br /><br />CD_Brockett... I'd suggest that you tear the unit down before purchasing parts. The forward electromatic coil may be okay, or as you say, it may be shot, but not going into gear can also be caused by a broken spring or other causes.
